OPPS I screwed up!!!!
While filling my fresh water tank on Friday I pulled the hose out and the spray nozzle disconnected from it's quick connector. Needless to say; the water flow and pressure carried the nozzle down to the bottom of the large tank filler hose.
Filling the rest of the tank was a slow process as the opening to the top of the tank was obstructed by the spray nozzle that is likely sitting above the tank at the bottom of that hose.
I know that the fresh water tank is under the stairs and that it can be viewed in one small corner by the inspection hatch just forward of the bunk in the mid cabin.
My question is where does that water fill hose connect to the fresh water tank?
Can it be accessed from anywhere inside the boat without tearing up the floor or tearing out the stairs?
