When I turn on the ignition switch and twest the key the starter solenoid will not engage usually until I twist the key several times to engage the switch. Volt meter on dash does go down a couple of volts when twisting key without engaging solenoid. I will check all connections again, but am wondering if using three rv batteries fully charged in parallel is a problem. Would starting batteries provide more juice to the starter solenoid to engage starter. The other possibility is my 1990 solenoid is getting tired.
Al
Al
