Head Board 1998 4788 Master suite-gctid391456
    How can I remove the head board at the chain locker so we can recover it? It seems to be so firmly bolted to the back wall at the head of the bed that short of grinding off the bolts inside the chain locker I can't come up with an easy way to get it off.
    Thanks in advance for any magic answers.
    Tim
    Tim Wing
    The Betty Jean
    There's 4 long screws in the chain locker that hold it on.
    Pat
    Paragon
    1999 4788
      How do you get into the chain locker?
      Horizon 68
      Sydney
        The mirror is hinged at the top, so it will pivot aft and up.
        Part of the wide molding strip that's covered in material will go with it.
        Two springs from the inside will hold the mirror in the up position.
        Pat
        Paragon
        1999 4788
          Thanks for that I will check it out.
          Horizon 68
          Sydney
