I just started getting a water leak at the outside of the aft shower on my 4087. It is at the forward end of the aft room, by the engine room access panel. It is right in the vicinity of the valve plumbing. I checked the interior of the shower unit for cracks in the caulking, loose fittings, diverter valve cover seal, drain, etc. It only leaks when using the shower, so I assume it is leaking from the hose that goes from the diverter valve to the shower head fitting, not the main plumbing lines.
It appears I could access the plumbing by removing the refrigerator? Before I do that, I'm curious if anyone has been at their plumbing. I certainly want to avoid removing the panels in the aft room if possible.
Thanks in advance.
Thanks in advance.
