Here's an interesting challenge.
My watermaker draws water from the seawater washdown pump through hull. That through hull is located in the lazarette.
While at rest, the watermaker runs fine.
While underway the watermaker picks up little air bubbles, and eventually the air bubbles accumulate enough to cause the watermaker to quit pumping effectively.
Of course I don't want to be limited to running the watermaker at rest. Watermakers are noiser than you might think, and I have to run it for several hours a day on average to keep up with water demands.
I believe that the bubbles are coming from the props since the intake is in that vicinity and the problem is only while underway.
I do not have another through hull to use, and I do not really want to install one.
How do I solve the problem???
One possible solution would be to use a intermediate tank, something like 5 gallons between the through hull and the watermaker. A pump would keep the tank full, and the watermaker would draw water from the tank. There are several technical details to work out for this solution but a tank would work.
Does anybody have a different idea, or any other advice?
Thanks very much.
Thanks very much.
