Syncronizer 330 Cummins-gctid390390
    Does anyone know if the 1999 or 2000 4788 come standard with engine syncronizers for either the 330 or the 370 cummins engines?
    a dial type synchronizer was part of the premium nav package that was available on either engine,,,it worked with a signal supplied by the tachs and wasn't that great,,you had to play with the throttles to get it to stay at the centre,,,not like true electronic synchronizers..
    84-38,,86-38,,89-45,,97-47,,99-47,,01-47,,05-540 meridian,, 04-411 meridian and 11 others,, all gone ,,now 04 -490 ,,sidney,,vancouver island.
      Thank you very much for taking the time to answer. This info helps.
        You wouldn't by any chance, know of a source for instructions on how to use the factory syncronizer?
          I orderd one from Faria for my 490. Installed it last year. It seems to work better at higher rpms than lower. The 490 was pre-wired for it so it was a simple install.
            Hi Brian
            I have the armstrong model syncronizer and sound stabilizer (the admiral's ears). It works every time, and takes no batteries.
            Hope your trip back from Roche was a good one. Nice to have met you and Liz there
            .... hope to see you on the water again this summer.
              there are no instructions that i know of.....the idea is to keep the needle in the centre by tweaking the throttles,,,
                Thank so much for you answers. This is my first larger vessel and I am finding out fast that there is much to learn about the many systems on board. Thanks again for your help.
