3270 Main Zinc Bolts
    After installing a new main transom zinc this year I must have broke the seal around one of the bolts. I now have a small leak. The bronze bolts I have are not long enough to have a locking nut on the inside of the zinc, which I think would help. Only room for two nuts and two washers, one on the inside against the transom the other on the outside for the zinc. Suspecting bronze bolts will be hard to find I was wondering if stainless steel would work? Have this happen to anyone?
    1987 3270 135-Hino
    Foxtrap, Newfoundland
    Any place that deals with wooden boats should have brass or bronze bolts. Admiralty Ship Supply in Pt Townsend WA has a huge supply.
    I put a large bronze washer under the zinc, i.e. Next to the transon, one on the outside of the zinz and then 2 bronze nuts. Have never had a problem with the zinc coming off or leaks.
    Jim
    1988 3270 With 135 Hinos
      I use stainless without problem. You really do need a nut locking the bolt to the transom, If the zinc deteriorates you could all the sudden have a very loose bolt and a bigger leak.
        Fisheries Supply online has all the bronze fasteners you need. Sadly this fix will require a grid or a haulout.
          Where exactly are transom zinc located on a 3270, or how do you access them?
          Matt Schneider
          1986 Bayliner 3270
          Washington, DC
            The transom zinc is in the center of the photo.
Name:	stern aft view.jpg
            100T MMC 2307794
