Westerbeke generator won(39)t start-gctid740192
    The stop solenoid on my Westerbeke generator burned out, stopping the fuel flow, shutting of the engine. I replaced the solenoid, but now the engine won't start. The battery is fully charged, I can hear a click when I hold down the preheat switch, but there is not even a click when I turn the start switch.
    Any ideas on where the problem lies are appreciated.
    Thanks in advance.
    Check your wiring placement on the new solenoid. It is easy to reverse wires don't ask me how I know. If you have a manual check the diagram. I assume the battery is good and fully charged.
    Richard
      Genset
      Are the gages working?
      No ÔÇô go to #1
      Yes ÔÇô go to #2
      #1
      - Is the battery switch "on"
      - Is the genset switch "on"
      - Is the battery dead (try dockside power for the batt charger)
      - Are you holding down the start switch while turning the selector
      - Are you holding the start switch for 3-5 seconds after releasing the selector switch
      - Is the small genset button breaker tripped (hard to push on genset in red)
      - Is the genset on engine toggle switch set to "on"
        "smitty477" post=740410 wrote:
        Genset
        No ÔÇô go to #1
        Yes ÔÇô go to #2
        #1
        Smitty, when you refer to "start switch", isn't it the "preheat" toggle switch to be held down? I think the OP will understand but thought I'd pipe in!
        Cheers
        John H
        Brisbane QLD Aust
        "Harbor-nating"
        2000 - 4788/Cummins 370's
          "Smitty, when you refer to "start switch", isn't it the "preheat" toggle switch to be held down? I think the OP will understand but thought I'd pipe in!
          Cheers"
          Yes exactly good point - it was labeled start on the earlier 38's and some 45's. I was guessing his boat had an 8KW Westy and a 38 maybe but just a guess.
