I guess if you're not fixing something every week you're not really a boater!
New problem with our 5788. Noticed that the fresh water pump was running constantly. Filled the tank (218 gallons) and the water pump stopped. Thought we were just out of water. Next day, a couple of vacuflushes and the pump started running constantly. To my dismay, I once again had to fill the water tank.
Pumped the forward bilge and a lot of water went over the side.
I'm embarrassed to say that I'm not even sure where the fresh water tank is (new owner) but I'm going to assume that it's under the forward stateroom. There is no water midships and no water in the engine room or lazerette.
I also do not know if this boat has an accumulator and if it does, where it is.
I'm a complete rookie with big boats but I think I've isolated the problem to the forward bilge and probably the fresh water tank.
What to do?
What to do?
