Packing size for stuffing box on my 1991 3288 motoryacht with 351 Windsors-gctid736832
    I have a question about my 1991 3288 with 351 Windsor's can somebody tell me what size stuffing are used in the stuffing box I know the shaft-is 1 inch and a quarter?
    I have been reading these posts for quite some time now They have been extremely helpful I have accomplished many of the projects on the 3288 that have been explained on this forum I want to thank everyone very much!
    Dan
    1991 3288 Gas 351 Windsers
    1985 270 Searay Chevy 454
    Interesting, you have a 3288 with 351 Windsors? I only thought the 38xxs were offered with a gas v8. It must get up and go.
    Joel
    1987 3818 Hino 175
    "Knotty Girl"
    Prince Rupert B.C.
      I picked it up little over year ago have done much to it but have been disappointed in the performance I don't have a speedometer on it but if I were to estimate I would say top and he's probably 24 mile an hour
      Dan
        That is a lot better than the diesel powered ones. What rpm are you running at that speed?
        Packing size is 1/4 inch.
        http://baylinerownersclub.org/index....-size-for-3288
        Joel
        1987 3818 Hino 175
        "Knotty Girl"
        Prince Rupert B.C.
          thank you for that information about the stuffing size where were you able to locate that?
          I was runningat 3800 to 4000 RPM at that speed I believe
          Dan
            Sometime if you use google search it works better than the search engine on the site.
            Is 4000 rpm the maximum rpm you are able to get, with a clean bottom and both engines tuned and running properly?
            Joel
            1987 3818 Hino 175
            "Knotty Girl"
            Prince Rupert B.C.
              I have been told that I should get somewhere between 4200 and 4400rpm but I am questioning my tax and how accurate they are one says 3800 while the other said I believe 4000
              Dan
                That's not horrible. These boats don't really plane (I tend to get disagreement on that issue) but check with a GPS. When you test have a light load and make sure your tabs are getting down all the way. I hit 28MPH once and I have the gas 305's. Regardless the boat is not designed to go fast, but arrive at a stately more gentlemanly pace
                My boat is happiest at around 8-10.
                  Yes I agree with Iceclimber, they are not really a true planning hull.
                  A 351 in a marine application should have a max of around 4800rpm, so I think you are a little bit overpropped.
                  Joel
                  1987 3818 Hino 175
                  "Knotty Girl"
                  Prince Rupert B.C.
