Aft window leaks on 32xx-gctid388265
    Hello everyone, I remember a member talking about a leak at the aft fake window area that ran down to the aft cabin, I do not remember the remedy, if it was the actual window frames, or the fake one, have that problem on both sides, any help would be greatly appreciated.
    In most cases, the drain holes under the rubber window track is clogged. (and in the rubber track also) Sometimes the aluminum rain gutter above the windows needs to be re-sealed. Sometimes all three combined to cause the issue.
    Bayliner also put the rubber track in a lot of places that it didn't need to be. (places were the windows can't slide too.) I have removed it from those places because it just makes the drains clog up, especially at the aft area around the black plastic panels. (fake windows)
