New controls on upper helm station--3288 with hino(39)s-gctid728470
    I am looking to "crisp up" the controls on a newly acquired 3288 on the upper helm station. What are my options? Can I just drop in Morse controls?
    I took mine out, cleaned them up and repainted. Turned out decent. And only cost me a few Dremel sanding wheels, masking tape, and a can of paint.
    I looked at new controls. There is a replacement controller available that will fit the exact hole. Uflex B50T and B50S
      Is it a pretty straight forward job to remove? Did you lube, or use new cables?
        Removal is easy. Just the 4 screws in the corners (2 are bolts) then pull it out and remove the pins on the cables. I have not changed the cables. I don't believe they can be lubed. If the cables are tight, they may need to be replaced.
        I did lube the controller with a dry lube
        Dean
