I'm refinishing my cockpit caprails and have stripped off all of the hardware and old varnish. I also cleaned out all of the butt joints between the teak planks:
[img]/media/kunena/attachments/vb/648444=23936-IMG-20120113-00045.jpg[/img]The depth of the wide area either side of the actual joint varies, but at it's shallowest is about 1/16". My questions are:ÔÇóis 1/16" deep enough?ÔÇóshould I seal the joint surface with something before I apply the caulk?ÔÇóif so, what should I seal with: thinned varnish or CPES (or similar epoxy product)?ÔÇólastly, choice of caulk: originally I planned to use Boatlife Life-Calk, now I've read good things about Teak Decking System's SIS440
