Exterior Cockpit lights on 3870-gctid708865
    Hey folks, has anyone replaced the two exterior lights on the outside, on either side of the doorway. The plastic on the round ones cracked and I need to replace. Found several interior types but need water proof ones like the existing ones. What have some of you used? Can you suggest an LED replacement? Thanks.
    Charles
    '89 3870 M/Y
    Located on Galveston Bay
    Prior boat '85 300SB Sea Ray
    Lost in Hurricane IKE
    I recently purchased new cockpit lights for my 3870 from Ebay.
    http://www.ebay.com/itm/Anderson-E12...FWQ0rw&vxp=mtr
      Thanks Pat but I was meaning the ones on either side of the sliding door on the ouside of the salon, ie cockpit side. The courtesy lights in the steps are fine. I appreciate the comment.
      Charles
      '89 3870 M/Y
        Here's one's I put in my 47. They are Lumitec and illuminate in (blue, red and dim-able they are small and really bright!!
        [attachment]22572 wrote:
        CockpitWhiteLight.jpg[/attachment]
        white)
        Family Boater
        1997 Bayliner 4788 w/330 Cummins - Phoenix
