I have a leak that is staining the fabric above the lights and windows on the port side in the rear section of the salon. I noticed one of the lights was flickering and dim, when I pulled off the puck light cover water poured out. So, water is draining into the area above the lights from somewhere.
After removing the shades and taking down the valance, I removed the staples holding the ceiling material so I could inspect the whole area above the windows. I inspected the hose connection from the scupper on the upper deck and all was dry. I had a helper spray water from above to try to see where it was getting in. Looking up into the area where there was black stains on the fiber glassed beam I could see water very slowly collecting on the beam. It is located above the back window area 7 inches forward and 4 inches in from where the scupper is located on the top deck. We aimed a stream of water into the scupper drain and found it to be totally blocked. We used a plumbers snake to run down the drain hose to get it unblocked. The starboard drain was blocked as well so we cleared it out too.
Again my helper sprayed the area from above as I watched from below and water was still collecting on the beam. It appeared that the scupper area had been caulked before by the previous owner and myself. We took a closer look at the area and found a pin hole in the fiber glass. We scraped and poked finding some soft material. I then cut out enough material forward of the scupper to see if the plywood board below the fiber glass layer was wet. Sure enough there was a cavity around the scupper that was a reservoir of water that has pooled.
Source of the leak is found! Now, I have to make sure it is dried out before I re-seal the area. I am gong to have a professional come out and examine the situation and bid on fixing it before I decide to continue on my own.
Lesson to share: Make sure your scupper drain hoses are clear and functioning.
