I've got 17x17x1 1/4, 4 blade props on the boat, but I don't have any spares. I found a set of 17x17x1 1/4, but they're 3 blade. Would there be a performance difference between these?
props...-gctid383851
You will have a 1 pitch change lower than the 4 blade. If the 3 blade were to be cupped you woud gain some of that back at higher RPM's.
I priced right they would be great spares, then buy them, I would, and have.
