Accumulater tank question: Trying to pump air in my accumuluater tank as the water pump is running constantly when water on. Using a small tire pump, but can not seem to force any air into tank. When depressing valve to see if any air comes out, tank would appear to be empty. Any ideas? Thanks
Accumulater Tank problems, 4788-gctid383582
Started boating 1965
Thanks for quick response. Guess I'm used to it being there and pump not operating constantly, so trying to continue using it as was intended. Was able to get a little air into the tank, and did help slightly. Will keep working on it.
discovered that is I turned pump off and bleed off water, pressure is reduced enough to allow me to pump air into tank. Works much better now. Thanks.
