I'm refinishing the Exterior Wood on the back of the Cabin and on top of the Transom and Gunnel. Does anyone know for sure the type of wood on either location? Some say it's Teak around the Cabin and Mahogany on the Transom any help would be appreciated.
3888, Types of Woods-gctid383443
My 1987 is all the same, Teak. I have had all of mine down to bare wood. Can't say for later models but it wouldn't make sense to change woods that mated. There would be some noticable difference imo.
Doug
our 3888 is teak inside and out.. and I too am refinishing the wood on the outside.. weathering is a blotch in southeast alaska for boats... :worth so putting my big girl undies on and baggy grubs and rolling up the sleeves to tackle it all.
good luck on yours.. post pics when done.. I too will post as well
Doug
did you sand and restain - any advice?
Thanks so much
Laurel
My '84 was teak throughout. The little triangles by the rear windows were teak verneer plywood. Stained? I think the interior was just oiled.
mcintyst wrote:
Did you redo the galley wood?
Thanks so much
Laurel
Thanks for all the comments. I did find that it's all Teak. My concern was on the wood that wraps around the back deck was gray and would not clean up like the rest of it. So I removed all the hardware (and it's a good thing I did) it was rotted out. Having it replaced, found Teak in a Lumber yard near me and took it to a friend of mine who has a wood shop. The rest of the teak is in pretty good shape and is looking good. I have 2 coats on and I'm going to do another 2.
OK, I am starting our cockpit teak. The next few days is supposed to be mid 80's.. so I went down today and blue paint taped around all the teak to prep and protect the fiberglass getting it ready for sanding tomorrow... I am taking before and after pics and will post them..................:worth
