I have just put in a re-manned pair of Cummings 370's and I have to run a new set of plug and play gauges up to the fly bridge. The old instrument panel in a unique shape and I already had to custom mount the manufactured panels on the lower helm station.$700 later it doesn't look as good as the original panels did.
4788 flybridge instrument panel-gctid381673
Started boating 1965
Bayliners owned: 26 Victoria, 28 Bounty, 32, 38, and 47 since 1996 -
mmichellich wrote:
Someone on this web site will make you new instrument panels for a 47 made from burlwood like material or black, including any unique cutouts you want. I am sure they will speak up.
David
1990 4588 "Salty Dog"
2021 Pure Watercraft all-electric HF 360
Past Commodore Puget Sound YC
Member Queen City YCComment
We didn't replace the gauges in the flybridge but we did replace the ones in the pilothouse.
The panels that Somesailor made up look better than the original.
He can make you up something for the flybridge, but that will require you to cut out the existing panel, and its thick fiberglass.
Just a question...
You went with fly by wire gauges???
Please do tell. Did you go with electronic engines, or did you add a transducer interface in the engine compartment and have some type of digital communications like NMEA 2000?
Whats the weather like on the boat https://www.weatherlink.com/embeddab...59665f4e4/wide
Where am I right now? https://maps.findmespot.com/s/218P#history/assetsComment
David
I've done a couple dozen pilothouses now. Shoot me an email: [email protected]
I can manufacture them based on either ABS or aluminum substrate (the base panel onto which the laser engraved burl is applied) and both work very well. Just a matter of cost. I'm revamping my website right now, but there are some pictures on here of Kevin's install. His look awesome because he put in all new gauges and Head units.
Tom
Tom Brooke
MV Overexposure - 1999 4087
MMSI - 367585640Comment
SomeSailor wrote:
I've done a couple dozen pilothouses now. Shoot me an email: "[email protected]" wrote: <br />[email protected]
David
Tombro wrote:
do you have a template for a 4087 motoryacht? Flybridge or down below?
Tom
To replace the dash panels in a 47, do all the wires have to be removed or is there an easier way to do it?
Bayliners owned: 26 Victoria, 28 Bounty, 32, 38, and 47 since 1996Comment
You do have to unplug all of the gauges if that's what you mean? You can do them one at a time if you wish though. Many times I make the panels from owner provided templates or drawings.Here's one of Kevins:
[img]/media/kunena/attachments/vb/685640=27680-Kevin Sanders 4788 helm.jpg[/img]
I'll post some better photos when I get off work tonight.
It doesn't hurt when you're not afraid to buy expensive stuff to put in the new holes either. I've seen some serious electronics dropped in these dashes over the years. Dual chartploters, Floscans, digital gauges, micro commanders, autopilots, you name it.
Fun to get to see some of these boats first hand too. Regrettably I didn't get to see Kevin's pilothouse, but I suspect he'll be back down this way picking up his Nordhaven some day.
ksanders wrote:
Here's a good one
