Cockpit hatch gasket-gctid381005
    Anyone try to install a gasket on the cockpit hatch of a 32xx? I get quite a bit of overflow into the engine compartment when washing the deck etc. and thought that might help.
    1986 3270
    Volvo D3 -160's
    Mine has a foam gasket, guessing 3/16" thick and about 3/4" wide. I replaced it a few years ago, found it online, self adhesive. There should also be a drain well around the hatch opening with a drain tube to the outside of the hull, check them for being plugged up.
    Jim
      I've put weatherstriping on every cockpit or lazarette hatch we've had.
      This keeps the salt water from the washdown out.
      Just go to Home Depot and pick out a suitable self adhesive weatherstrip and install away.
      Its a great addition to any boat.
        Hum...I also wonder if your drains are clogged. I don't get a drop of water in the bilge when hosing out the cockpit and I have nothing under the hatches.
          If there is no rust on your engines from a salt water wash down you are not using enough water or catching enough fish. :sorrow:
            Sounds like I need gaskets and a drain hose cleaning. Thanks everyone.
            1986 3270
            Volvo D3 -160's
              If I get salt water anywhere on my boat, I'm in trouble. We're on a lake.
              To the OP, perhaps try lifting the hatch and let a little water drift across the deck onto the hatch rim. You should be able to spot where it's sneaking it. I am certainly no expert but I feel that hatch rim is designed to ship water out the drain - as in no sealing required. But, I was wrong about something yesterday too.
