I am installing a D4 Espar in a 3218, were would you guys install the thermostat?? We like to sleep in the cave, all rooms have a heater duct,
forced air furance-gctid380191
On my 38, the thermostat is at the helm station, about 2 -3 feet off the floor. The forward state room will get cold if you leave the door open.
Rick
We are buying a 3218 and would like to find out more about your install. Is it a new install or are you replacing an older unit. Where is it etc. Pictures would be awesome!
My espar stat is in the saloon on the electrial panel. When I lived aboard it ran 24/7 in the winter. Now that we have move off we only use it in the spring and fall.
FYI I moved my AC stat to the aft cabin and love it there. If I was installing a new espar I might consider installing it by the bed.
1987 3270MY, 135 Hino engines
2015 Element ( Lime Green) Limited Edition 75 HP Mercury.
Roger, Lake Saint Clair, Michigan
Fair Winds & Following Seas
up to 76
1988 3270
135 hinos
Seldovia ALASKA
KEVINS UPHOLSTERY
KEVINSBOATTOPS.COM
Marine canvas/Upholstery
since 1975
We installed ours on the vertical bulkhead to the right of the stairs leading to the aft cabin. Our unit (Webasto) is installed in the cave and so we ran the wires under the "monkey fur" covering. Nice neat location and is easy to turn on as your entering the cabin. My only wish is that the thermometer was lighted.
Trev
