trailer for a 3218 bayliner-gctid379876
    I have done alot of pricing boat lifts, to get one shipped to where i live is in the $15,000 range, a little pricey for me..guess i,m going to end up going with a trailer. Anyone know where i could get a good price on a trailer ? New or Used does not matter..
    VATB-12625 ST225/75D 15 LRD 6H 12625 29'-32'* 2 5/16" Standard 3
    VATB-15025 ST235/80R 16 LRE 8H 15025 32'-36'* 2 5/16" Standard 3
    http://www.venturetrailers.com/aluminum.html
    Looking at buying one of these loacaly here in Seattle, new cost is around 7K, might be less for you as these are mfg on the east coast.
      Good luck on fimding a used one. I looked for more than 2 years before i decided to make my own. Also a good new trailer that will carry the load of your boat is hard to find and expensive. Dont forget that the load of the trailer includes the weight of the trailer and all your liquids and junk you are foing to need a 20000 lb capable trailer and a truck to pull it.
      New and. Used ones are out there but few and far between. I found it difficult to find a used trailer that wasnt really beat up or worn out
      1989 Avanti 3450 Sunbridge
      twin 454's
      MV Mar-Y-Sol
      Twin chevy 350's inboard
      Ben- Jamin
      spokane Washington
        Depending on what your boat is, I think you might want to consider a higher capacity trailer. The 15K trailer will be marginal at best for a 3288. Dry weight is approximately 13K. Add fuel, water, gear, accessories you could easily add another 5K to the weight. That would mean for a degree of safety one would need their 18K trailer.
        Patrick and Patti
        4588 Pilothouse 1991
        12ft Endeavor RIB 2013
        M/V "Paloma"
        MMSI # 338142921
          13000+5000 + 3000for the trailer= 21000 lb trailer thats heavy even for a 20000 lb trailer.
          However i towed my 11000 lb boat 300 miles on a 12000 lb capacity trailer (that was a16000 lb gross loadwith all the the fuel and junk) that I borrowedonly because I had a friend that used it for his maxim 32scr. Now I thought that because he did it would be fine. It towed like crap and I wouldnt do it again
          twin 454's
          MV Mar-Y-Sol
          Ben- Jamin
          spokane Washington
            I was a little confused by their website. They showed the weight as "Load Capacity", not GVW or Gross Weight. The assumption and it may be wrong is that this is the maximum load that can be put on the trailer. Unless you have found something stating otherwise on their website or through conversations with them.
            Patrick and Patti
            M/V "Paloma"
            MMSI # 338142921
              Anyone have any sketches or measurements to build a homemade trailer ?
                Here is a link to my trailer building thread. Its not a job for the faint of heart or the unskilled. Mine took me most of one summer to build then last summer I went back and changed a bunch of things I didnt like. If you want measurements I could give you some but my hull is a planning hull and my bunks would be different than what you have.
                http://www.baylinerownersclub.org/fo...g+boat+trailer
                Now its my opinion that what I have is much better than what a person can generally buy. Not touting my abilities its just that alot of the trailers I looked at were not built very well and were engineered to the minimum. A trailer like I built would be in the $10000 range. I spent about $4000 - 50000 on it. Its a 18000 lb trailer because of the axles I used you would need 7000lb+ axles.
                twin 454's
                MV Mar-Y-Sol
                Ben- Jamin
                spokane Washington
                  WOW ther trailer looks great !.. heavy duty for sure..
                    I have a Blair, purchased used from another BOC member a couple of years ago, its a great trailer. 5th wheel style with a gooseneck. Electric over hydraulic brakes, loads and unloaded very easily (boat).
                      Is it possible to get some dimensions from this trailer? I'm wanting to build one exactly like it and it would make it so much easier if I had the dimensions. Thanks, Russ
                        Are you by chance in the Puget Sound area? If so, years ago there used to be a 32 Bayliner on a trailer at Dagmar's in Everett. You may want to see if it's still there and measure the trailer.
                        2013 Boston Whaler 130 SS
                        Isla Verde, PR
                          Send yachtman a PM he built his own.
                            Or you could buy mine, see Classified section.
                            Jeff & Tara (And Hobie too)
                            Lake Havasu City, AZ
                            And 13 others...
                              Thanks, I'm in Tennessee. I'm probably more excited about the project of building the trailer than I am about the actual need. Thanks for the help. I'll PM Yachtman.
