I have a feeling this will unleash the 'Gods of Gummed-up Turbos' or the like, but are people trolling with diesel engines in the 32's? I know one 32 on my dock has modified his swim step to mount his outboard (nicely done, BTW) , and he's got gassers. Anyway- any issues with doing so? Obviously the water current matters, but are you able to maintain a slow enough speed with one engine? Any impacts to diesels loping along like that for long periods? Thanks, Dean
Trolling with Hinos?-gctid379403
They work great just blow it out on the way in and then let it cool. One thing to be aware of is drive plate wear. Trolling takes a toll on the drive plates, watch for increased vibration and be prepared if you plan on doing a lot of trolling. Or better yet replace them with the new kind they have now I can't remember the name but they are much more heavy duty.
The Hino power curves don't even start until the low 1,000's, suggesting they are not intended for normal operation in this range, and certainly not at idle - consider running at least at fast idle. Many report problems and failure of transmissions when operated at idle for extended periods - again, fast idle is recommended to prevent excessive rattle and wear - you should be able to clearly hear when the rattling stops, say at 900 rpm. But if you must run at low idle, follow the other post recommendations to increase speed at the end of your trolling run to blow-out the carbon, at the least to the minimum power range shown on the engine curve - should be in the 1200 to 1500 rpm range. - Good luck, Doug S.
I know several avid fishermen with the 32's and they all do it on one engine. I did last fall for the first time and it worked great.
Thanks for the comments, I'll give it a go. I probably will keep the overall hours down if this impacts the transmission plates, given the Hurth 360's have never been rebuilt and are approaching 1500 hours. Oh, and thanks for all the forum help on getting me to spend $500 for electric downriggersThanks, Dean
I've done a lot of fishing on my friend's 32' - we had a lot of luck running with one engine and two large sea-anchors off of the front two cleats (tying the back of the sea-anchor off on the midships cleat to keep them rolling under the boat on a turn). This way, we were able to maintain a good trolling speed and bump the idle up enough to keep the pressure off the flex plates and transmission. Worked great. I'm now trolling on my 3870 with one engine - so far with no success...which has nothing to do with the engine :thumb
I have a 3870 with 175 Hinos and was wondering...when you guys troll with one engine, do you shut the other one down or let it idle in neutral?
My question is at what RPM is the pressure off of the plates? Can you hear when this occurs?
