Mid cabin ceiling removal on a 4588-gctid379219
    The rail supports on the port sides are loose, two of the four bolts do not have nuts on them. I need to pull the ceiling down to get to the backing plate. How do I pull it down?
    What Rail? In the mid stateroom, the sofet over the port holes has screws that go up by removing them the sofet drops and you have access to the rub rail and toe rail nuts.
    Not sure I understand where you are trying to get to?
    Mark
    USCG OUPV
    1990 4588
    Carlsbad, CA
