dummy radio antenna flag pole-gctid378733
    Want to fly a few flags - don't want to leave them up all the time. Have a couple of extra antenna mounts on the radar arch. Anyone know if "they" make a flag pole that will screw onto an antenna base? And if so - who are "they" and where can "they" be found?
    ________________
    1998 Bayliner 4788
    1989 Bayliner 3270 - SOLD-
    Or go to Popeye's and get some cheap used antenas
      If the mount is stainless, it will likely work. If it is plastic, you risk losing everything overboard in rough water.
      Started boating 1965
        Yup - on the list for sure
        ________________
        1998 Bayliner 4788
          We have a old CB antenna that the previos owner left but cut the wire. We fly our Officers Flag off of it without any problem. It's plenty strong enough and you can get the clips that will work with it.
            struck out - no antenna's at Popeye's... bummer...
            ________________
            1998 Bayliner 4788
