Dual shore power plugs 32xx-gctid378583
  • Dual shore power plugs 32xx-gctid378583
    Most boats I notice with 30A shore power have a single plug into the boat's system. Mine has 2, and there are 2 main breakers on the AC panel. Why would that be? It seems to me that 30A at the shore outlet = 30A at the AC panel, what is the purpose of dividing the supply into 2 circuits?
    Paul
    2002 2859 Ciera Classic, 350 MAG MPI, Bravo II
    2013 Tandem TuffTrailer
    2005 GMC Sierra 2500HD, 6.6L Duramax/Allison
    I would think it would be for the AC... I have 1 30 amp on my boat and going to add #2, 30 amp just for the AC....
    Just my thinking on it.....
    BUCKANEER
    :arr
      Factory A/C had two inputs.
        It means that you could have 60 amps to the boat...mainly necessary when the boat is prewired for A/C.
        I have similar on my 3587 and have 2x30 amp cords to the boat.
          Just to avoid possible confusion - the AC or A/C referred to in the responses is Air Conditioning, as opposed to the AC for Alternating Current in the original post
          "Allante I" Rayburn 75
          Previous: '97 4788
            On my 38, one input supplies power to the aft part of the boat and the other input supplies power to the fore part of the boat. I use a splitter pigtail to connect the single 30A power cord to the two inputs.
            MMSI: 338030604
              I do what Cannonball does. By having a splitter, I only need one 30 amp service. It is possible to overload the cuircuits this way. If ran A/C, Stove, Water heater and something that draws a fair ammount of current of a recepticle, you could overload a single 30 amp line. Just don't run em all at the same time and you'll be fine.
              Doug
              Hanging Loose
              98 Carver 350 Mariner
              2013-
              KRUSTY KRAB
              2001 305
              5.7 BII
              2006-2013
                :worth :worth
                BUCKANEER
                :arr
                  Some marinas, like where I'm at now, have two 30A outlets for each slip, so you'd run two 30A cords to your boat. I also have two inlets, one feeds the aft A/C and the other the FWD. Down here it's good to have two A/C's.
                    +1 on the splitter. I used to wrestle with two cords and it was a pos. Plus my moorage only had one plug in per, so I was constantly having to find a spare from an empty slip. With the splitter I have found inner peace.
                      Bodie, my 1987 3218 is wired just like yours. No AC ever on the boat. I don't know why they did this but it was really
                      nice when I wired my inverter, I dedicated one of those circuits for the inverter so there is no way someone can turn
                      the wrong thing on and drain the batteries.
                      Steve
                      1987 3218 (sold)
                      135 HINO
                      2016 Past Commodore, Swinomish Yacht Club. La Conner Washington
                        Having two 30 amps inlets gives you the possibility of connecting two 30 amp cables to two 30 amps outlets and drawing 60 amps without overheating. By using a splitter you can sometimes draw 60 amps on one cable which is supposed to hold a 30 amp load only thus a lot of heat on the cable and the outlet and voltage loss. When on one cable you have to avoid running two A/C, the water heater, the battery charger and the hot plate together. limit the power draw to 3500 watts.
                        NILE
                        1989 3288MY 305's US Marine
                        Fort Lauderdale Florida
