I would like to replace the factory davit whit one mounted further aft and supported by a base bolted to the cockpit sole and have an 800 lb. capacity. Has anyone done this and where might be a good place to look in the PNW for a replacement?
Davit for 45XX-gctid378058
I am in the process of replacing my factory davit on my 4588. I am currently in contact with Advanced Marine Technologies in Vancouver. I have some .pdf drawing is you care to look at? The problem/solution is the rotation of the cran to clear the radar arch. I too am looking at mounting the base more aft. Here is a pic of one of there solution on a 47, I think?
[img]/media/kunena/attachments/vb/681517=27261-Mounted to port side.jpg[/img]
David
1990 4588 "Salty Dog"
Past Commodore Puget Sound YC
The picture above is of a stock 47 base and post but with an aftermarket arm attached.
While I am sure that it is possible to add a more robust 45 davit we are unaware of any from our experiences.
Please note that the 45 and 47 do not share any parts between their davits and that the flybridge deck construction as well as the flybridge sides vary greatly in their load capability and dimensions.
I would be concerned that the 45 can handle extra loads based upon that construction but if that is a goal I would attempt to keep the most weight over or near the underlying rear bulkhead formed around the saloon door.
Hope this helps
Another option is to go with a transom davit. Below is my 4588 with a 1000lb Nick jackson Davit with a 11' AB RIB with aluminum hull about 700# loaded.
This also frees up your bridge deck space of other things. After having the stern davit I would never consider gong back to the Bridge davit. I can also single handed launch the dingy Less than 2 min.
"TRT" post=701366 wrote:
Thanks for the pictures. What did that system cost?
We have done this upgrade a few years ago. When with Brower 800 lb hydraulic linear winch model WC800
http://www.browersystems.com/products/wc-series/
We did not move from the existing location but built a stronger base and tied into the existing superstructure that was in place.
Call Brower and ask Russ, they are very responsive and do a great job...PM me if you would like, happy to answer any other questions
Mark
USCG OUPV
1990 4588
Carlsbad, CA
