broken saloon window 4588-gctid377822
    one of the windows of my 4588 is broken. I find a supplier to deliver a new window. But the window is to big to install. How can I get the glass in the frame ?
    You need to use the same suction tool used to install automobile windhields. Maybe call a mobile auto glass company.
      hi uncle Bob,
      the suction tool is not the problem, I cannot get the glass in the frame. I think that I have to remove the seals first ?
        Remove the top seal first then the bottom one. They are fairly easy to pull if you move the window open a couple inches. There is a slot behind the seal that is deep enough to lift the window up then swing the bottom side out first.
          thnx
