Hey guys, i,m new to this site , have found alot of info here already that i didnt know about my boat . I have a 1988 3288, had it 1 year. It has twin 135hp hinos , i have a issue when i start both engines all is good. after about 20 mins of running the stbd Engine tachometer and oil pressure gauges start to jump around . any one know where i could look to fix this problem , help would be greatly appreciated ! Thanks.
1988 bayliner 3188, hino Tachometer and oil pressure gauge trouble-gctid376425
LTCret wrote:
An easy start to the process of elimination is to check the condition of the main wiring harness plug-in connections. All your wires leaving the engine normally run through this plug.
Good Luck
Started boating 1965
Good Luck
Your tac sender is probably this unit:
$53 is pretty high I think mine was around $42 so shop around...
Hope this helps.
FishingFool wrote:
+1 on that.. if that does not do the trick then you should check the sending units that are on the engines. I just replaced all of mine, fuel, Tac, Engine temp and oil pressure.. All gauges work now. The sending units go with the gauges, you probably have Faria gauges, you can Google Faria and find there website. Call there and talk with Jason Clarke X1229.. Tell him you have Diesel's and need the correct sending units, he will give you the model numbers which you can Google to find the best price.
Hope this helps.
The manual is a little hard to follow but the info is all there. I had to read it a number of times before it made sense.
keatig wrote:
Not sure what gauges i have they are th flat square type, not the round ones ,i know that much ..
keatig wrote:
yeah there the star wars ones i guess, i think they are still US Marine though,
