Hello all, I have gravity water being supplied to the toilets (jabsco electrics) from the water supply before the water pump.
When the water level in the tanks is high, the bowls fill with water, and the rear head on our 4588 has overflowed once. When the tanks are very low on water the toilets suffer from working too hard to get water.
I am planning to install a 12 volt, normally closed solenoid on each of the toilet supply lines and having them energized at the same time the toilet pump is activated. Water supply will now, come from the pressure side of the system with perhaps a flow restrictor if the water flow is higher than required.
Can any interested readers shoot holes in this plan or suggest a better idea?
Thanks all. Cheers steve
