we need to replace the bolts for the transome bonding zinc... what type of metal should be used.. its limited here in town what we can get????
what metal bolts???-gctid373859
I have always used bronze for transom zinc bolts, washers and nuts to attach to the boat bonding system. A haul out yard should have these, especially one supporting the fishing fleet. You need multiple nuts and washers per bolt.
Started boating 1965
Bronze or stainless, I use all thread rod and fender washers on the hull and std washers and 2 nuts between the hull and the zinc as well as a washer and 2 nuts on the aft of the zinc. Reason for 2 nuts between the hull and zinc is to provide the maximum surface area exposed on the zinc. I hace never had a problem using stainless on the zinc, just as the shaft and rudder and trim tab bolts are Stainless.
The all thread also allowes you to connect your bonding wires on the interior without removing a bolt.
The ship chandlery in Juneau should have everything you need, 1000 Harbor Way.
Go with stainless all thread, I have worked on and installed zincs on boats since 1994, never saw bronze bolts (all thread), and they are spendy.
RinnyBeth wrote:
thats Juneau Electronics now... Chandlers is gone and has been a long time..
You might try a hardware store for the stainless threaded rod-washers and nuts. I know that in Seward both hardware stores have an assortment of SS threaded rod, I would think that there would be someone that has the 3/8" threaded rod, if not maybe someone closer could mail one to you, Fisheries supply has 3/8 x 16 SS rod.
RinnyBeth wrote:
thank you, the Capt found the bolts we needed in the local hardware and boat store a few blocks from the drydock.. its a plumbing store and they have half the store with marine items... worked perfect and she was put back in the water today at 4..
:worth:worth
I broke down and bought new manifolds and risers for both engines last week, they arrived today. Now the fun begins actually replacing them. I have done this on automotive installations many times but never on a boat with the engines still in place. Any recommendations on what not to do? The inboards are relatively accessible but the outside of the engines are very tight. This is a Volvo (small block chev) 305. I just don't want to snap a bolt on the outside bank since the next thing would be engine removal to get it out. It will be a socket on a breaker bar for the outside and impact tools on the inboards. Anybody have any other suggestions? :surr
