I've noticed that even some of our most experienced owners have had events where the wrong filler cap was selected for whatever function. I've almost grabbed the water for diesel. The guy next to me with the same boat has small color coded and engraved plastic/phenolic plates glued next to the respective filler caps. I'm curious if anyone has used a different approach for this. I thought of painting but assumed it would not stick well to the chrome surface. I'm looking on having the plastic labels made, but haven't found any place yet that does just one label. I know that one should simply pay attention, but also that stuff happens. Thanks.
Marking Filler Caps Fuel, Water, Holding?-gctid372980
I purchased several stick on letter/decals in blue then I applied them. Directly about( 3 ") above or below the caps on the side of the boat (0n the Fiberglass). Looks great and yes they do work. This way you or the personal on the dock can read them also. When taking on fuel, water, or getting a pump out.
From the stearn going forward
Water, Diesel Fuel, Waste
1987 3270MY, 135 Hino engines
2015 Element ( Lime Green) Limited Edition 75 HP Mercury.
Roger, Lake Saint Clair, Michigan
Fair Winds & Following Seas
The kiosk in the mall can make up little lamacoid labels for you, to your specifications.
[img]/media/kunena/attachments/vb/676408=26657-lammy2_010.JPG[/img]
interesting, here in the UK the Boat Safety Scheme states that all filler points must be permanently labelled on the deck fitting, not the cap. without the correct makings your boat will fail, no BSS cert no license, no boating
Started boating 1965
Mike: I did not see the tag making business you referenced as the kiosk in the mall. Did I just miss it? Thanks, Dean
Thanks, Dean
You can also buy colored caps. Blue for water, red for fuel and black for oil or waste. Here is an example but there are many type and manufacturers
[img]/media/kunena/attachments/vb/676802=26729-filler caps.jpg[/img]
Dave, I hope your memory is better than mine. Lets see blue is water, no waste, uh------
I have to join the crowd that has screwed up also. But no markings would have saved me. I filled my Sea Ray that was on a trailer.
Found the cap over my head, removed it, emptied 5 gal of gas then thought about it. Better look.
Yup, it was the holding tank.
There was gas in there anyway.
Doug
Doug
http://baylinerownersclub.org/media/....jpg[/img]
toukow wrote:
I found the ones you showed and they reference the Sea-Dog deck fills. Has anyone used this with the Bayliner fill fittings or are these all pretty much interchangeable? After seeing Johnny Vintage's current post on diesel in the water tank, makes me want to make sure I do something along these lines given my new plastic tank. Thanks, Dean
ÔÇóThese slotted caps fit the 357000-1 or the 357001-1 Sea-Dog deck fills.
mmichellich wrote:
Looks like green is there for us diesel folks.
