4588 Salon Window Sliding Window Track/Seal Source-gctid372923
    Looking for a source for the seal/track that the salon windows ride in on our 4588. Does anyone have the source for these?
    Patrick and Patti
    4588 Pilothouse 1991
    12ft Endeavor RIB 2013
    M/V "Paloma"
    MMSI # 338142921
    I have read on the BOC site that the sourse is : CH Laurence product, #AS134096. Do a search started by Trebor, "Help with window track install'. Trebor has a 3218 and I am not sure if his windows are the same a 4588, but its a start.
      For my 1996 4087, the lower channel is a Stan Pro, part number 75000638 (AS-1528). The distributor I purchased from is Austin HArdware, (800) 821-3520. Cost is $6.80 for an 8 foot piece.
        Upholstery Supplies Auto Marine and Furniture from Perfect Fit in Portland Oregon and Kent Washington. Your one-stop shop for all you upholstery projects.
        Located in Tukwila, WA just south of the Costco/HomeDepot area.
        They have most of the canvas/plastic/upholstery/trim for marine. You can take in a sample or I can check my receipts and get you the numbers.
          Thank you. The prices are across the board I will make some measurements and see which come the closest.
          You guys rock. Thanks again.
          Patrick and Patti
          M/V "Paloma"
          MMSI # 338142921
            +1 Pat this is a great place to do business with
            Bill
              Thanks Bill, by the way, thanks for the tip on Dalys Paint. They matched the teak perfectly. They really know what they are doing there.
              Patrick and Patti
              M/V "Paloma"
              MMSI # 338142921
