Aprox Dry Weight of 3250 Explorer-gctid371920
  • Aprox Dry Weight of 3250 Explorer-gctid371920
    I have a 32 Expolrer which I need an approx. weight of.It's a 1983,gas engines.I'm just seeking a ballpark number.Thanks
    11,500-12,000 pounds
      My 3288 with full water and fuel...gas engines was just a tad under 15,000 lbs on the crane hook.
        Makes sense...almost 3800 lbs in full water and fuel
          My 1983 3270 weighed 14,000 pounds on a DOT scale (I weighed the empty trailer to get the net).
          It had 6-cyl gas engines at the time, a 9' fiberglass Livingston skiff, no water, no fuel. I estimated there was about 1,000 pounds of gear on board.
          So -- right at 13,000 pounds. Bayliner published 13,720 pounds as the weight with partial fuel (whatever that means) and 400 pounds passenger weight.
          100T MMC 2307794
            Is it a 3250 or an explorer? They are not the same boat. A 3250boat weighs 10850 dry. Depending on the model maybe more if its a fly bridge model. I think those are near 12000lbs. Explorer is a displacement hull a 3250 has a planning hull. 3250 also known as a conquest.
            1989 Avanti 3450 Sunbridge
            twin 454's
            MV Mar-Y-Sol
            Twin chevy 350's inboard
            Ben- Jamin
            spokane Washington
              The OP asks about an Explorer.
              Started boating 1965
                The op states in the title that he has a 3250 explorer. Not the same thing.
                twin 454's
                MV Mar-Y-Sol
                Ben- Jamin
                spokane Washington
