When I pulled my 3270 last summer to adress an overheating problem, the port prop showed signs of corrosion (stbd was fine). The first thing I noticed was no anodes on the prop shafts so I added them to both. Afterwards, I was told by several people (here at BOC and by a fellow at the boat yard) that 3270's didn't normally have anodes on the shafts and that the boat's grounding system took care of protection from corrosion. I thought to myself that the football anodes I had added would take care of the situation, irregardless of what was going on with the grounding system. Not so, I've just pulled the boat again to replace the damaged prop and see that it is corroded even worse than it was when I looked at it last time the boat was out of the water. The stbd prop is still undamaged.I had a good look at the bonding wiring in the engine bay yesterday and see that from the main bonding wires running along the centre of the floor, forward to the engines, there are short lengths of wire T'd off near each of the dripless shaft bearings. One short wire has the remains of a ring or spade type connector at its end, and is long enough to have once been connected to the shaft bearing (or something else in that vicinity) in some way. The other short wire is devoid of any signs of a connector, but is also long enough to reach the area of the shaft or shaft bearing. There's no apparent way to attach wires to the shaft bearing itself, but there are signs, on both shafts just forward of the shaft bearings, that there may have been something, like a brush, touching the shafts at one time - there are light scratch marks, ringing the shafts, about an inch and a half forward of the shaft bearings.I vaguely recollect the PO saying something about the dripless shaft bearings being fairly new. Is it possible he just replaced the old bearings, which had some form of attachment for the grounding wires, with the new bearings and didn't bother re-attaching the ground wires? Replacing those bearings seems like a job for a professional, and it doesn't seem likely a professional would leave the grounding sytem incomplete.Four questions then:1. Is there supposed to be some way to attach the ground sytem to the shafts, or to the bearings?2. If both ground wires have been unattached, why did only the port prop suffer such extensive damage while the stbd prop remains unblemished?3. Why did the anodes I placed on the shafts not prevent further damage to the port prop? They have been doing some kind of sacrificial work, because they are pitted.4. Can badly pitted bronze props be repaired?I'm going to the boat in a while and will take some pictures of the dripless shaft bearings and wires and post them later today. Below are a couple of pics of the damaged prop:
[img]/media/kunena/attachments/vb/674656=26458-Prop1.jpg[/img]
[img]/media/kunena/attachments/vb/674656=26459-Prop2.jpg[/img]Here are a couple of pics of the shaft seals:
[img]/media/kunena/attachments/vb/674656=26517-shaftseal1.jpg[/img]
[img]/media/kunena/attachments/vb/674656=26518-shaftseal2.jpg[/img]
