Down riggers and V Drives-gctid371013
  • Down riggers and V Drives-gctid371013
    I am thinking about installing downriggers on my 3688 with V drives.
    My concern is getting the line wrapped up in the props of course.
    I would locate as far aft as I could.
    Anyone else out there with a similar application?
    Do you have line cutters installed?
    Do you use the long booms on the downriggers?
    I had a 2452 before and am going through some salmon fishing withdrawels by not being able to use downriggers.
    I have Scotty electrics.
    Looking for advice before I get into this.
    Thanks,
    Corky
    Corky
    1992 3688
    Bellingham
    Mount them on the stern quarters and point them straight out the sides. Let enough fishing line out so you can still make a slow turn.
      Agreed, right at the stern corners, if you have line cutters on your props switch the stainless cable out for braid on the downriggers, you should be good from there..fish on
        Outboards and outdrives are the worst for getting a downrigger line caught in the prop. Inboards and V drives obviously the best. Just turn slowly and don't back down catching a fish unless the downriggers are up. With Scotty electrics, it is so easy to just push a button to raise the downrigger and fish landing should be done with all downriggers up, a large fish can run the line around a downrigger cable and then around a prop. It is not fun watching a fish jump out behind you boat tied to a line and you have no line/pole in the water. Don't ask me how I know. It is possible to net said fish tho, from a dinghy.
        Started boating 1965
