Marine Air System-gctid370320
    I have the Ecu Maxx system, and the control panel has a faulty display. With one of the red lights that make up the display not working, its hard to read what the fault "number" is. While I will swap from the main cabin, to try to fix my not working issue, I was surprised to see a replacement control panel is some $420.00. Any one know a cheaper source?
    Cheers
    Here is a site that does have some of the controls.
    http://greatlakesskipper.com
      Thanks, they do have a few, however not the same as I have. Not sure if they are interchangable.
      cheers
        This unit is identical to the one in 4087, which is 1997 vintage....Your boat must be a bit newer>>>>
        http://greatlakesskipper.com/product...y-control.html
          Thanks Trev. That does look like it, only ours is black. Odd that I could not find it. While cheaper that $420, at $199, thats still an ouch.
          Cheers
            Peter
            Here is a PDF on the system from Dometic and I think they have the control switch you are looking for in here
            http://www.mabrumarine.com/pdf/marine_air_controls.pdf
            The link below is to find a dealer, you may have to buy it from the US being 120V system.
            http://www.dometic.com/enus/Americas...-Air/Controls/
            You have probably looked here before but just my 2 cents worth if you haven't, good luck with it
            Hugh
            Hugh
            1990 3888
            Hino 175 Diesels
              They may be able to help you here.
              http://marine-ac.com/forum/?group=1
                Thanks Hugh and Doug
                Cheers
                  If you find it here somewhere, let me know, I'll get it on it's way to you...
                  Jeff & Tara (And Hobie too)
                  Lake Havasu City, AZ
                  And 13 others...
                    I was in Brisbane back in February and either I or some of my staff wil be back down there in June. If there is anything you need sent down just let me know. I also have some other stuff I will be shipping down so let me know if I can help..
                      Jeff and Trev, thank you both for your kind offers. At this stage, I am goiing to swap units, in an attempt to isoloate what the problem is with the one unit, and then decide where to go from there. At $200 its still a bit pricey.
                      I have a mate that has a container coming from Whiting, ID just about every month, so for non urgent items, I get shipped there. Every now and then I stumble across a business that will not take an international credir card, so that adds to the degree of difficulty. Trev, now you will have to expand on what business you have here in Brisbane. Use PM if you like, you have *****ed my curiosity. If you visit again, you wll have to let me buy you a beer.
                      Cheers
