Has anyone removed the teak trim that starts in the salon at the door crosses the galley and ends aft at the window? I drilled out all the teak plugs, removed the screws and the starboard side comes out easy enough. The three pieces that run mid-ship across the galley appear to be glued or perhaps nailed in at the bottom. If you have done this what is the trick, if the tiny circle marks near the bottom are nails do I just drill through them? Or cut with a saws-all? I want to make sure I get it out clean for the new varnish. Any ideas or suggestions will be appreciated. I attached a pic.
[img]/media/kunena/attachments/vb/672840=26225-trim38.jpg[/img]
