1989 3288 with twin HINO DIESELS and damaged rudders. How much can I expect to pay for 2 new ones? Where is the cheapest place to purchase? Is this a job that I can do myself? I have some mechanical ability just not sure about the job specifics. Anyone who has done this job before or has purchased rudders please reply. MIKE
3288 rudder-gctid369267
Edit- company name is Marine Hardware. If you need rudders you may also need struts and shafts which they also have. Do a web search for contact info. They ship all over the world.
Started boating 1965
If the rudders are bronze, and the shafts are SS, it is possible to pull the shafts out and replace them, there are aftermarket rudders, all you need is the shaft diameter, and length, and approx. rudder size.
Look up Algonquin, and possibly Foss, and others, also look for salvage boats, there are more and more boats being junked. New rudders are quite spendy.
1.25 diameter stainless steel shafts with bronze rudders. I contacted marine works and they wanted $1500 . OUCH!!! I found a local welder here in Virginia that fixed the shafts and both rudders for $700. I suggest you do the same. Unless you are rich.
