Gents
I have had some impeller challenges with the sea water pump (Westerbeke part # 33636) on my 3818.
So Ii went hunting for alternatives other than the Westerbeke impeller part # 34440.
I was able to cross reference the par number to several different makes.
Here below is what I found at this very useful web page
http://www.boatersplus.com/globe-com...ller-6541.html
You will need to use Internet Explorer to open & view the attached mht file.
Westerbeke pump is model / part # 33636
Globe Composite Solutions 6 Blade Globe Impeller 6541
PRODUCT CODE: MM-GB6541from BoatersPlus.com
ÔÇó6 Blade Globe Impeller
ÔÇóReplaces Jabsco 673-0001, 1133-0001, 18673-0001
ÔÇóReplaces Johnson Pump 09-1026B
ÔÇóReplaces Perkins Diesel 24880194
ÔÇóReplaces Volvo 897055, 875808, 804696
ÔÇóReplaces Westerbeke 34440
ÔÇóDoes not included gaskets or o-rings!! If needed, please contact us for assistance.
ÔÇóImpeller dimensions: Height 2"
ÔÇóWidth 7/8" shaft diameter 1/2" pin drive
ÔÇó6 blades
ÔÇóAll Globe impellers are made from elastomers giving them the combined characteristics and multiple properties of rubber nitrile viton and neoprene
ÔÇóThe only impeller in the world guaranteed to run dry for 15 minutes
ÔÇóTriple the service life
ÔÇó6 blades
