Need a source for oil filters. I called a local boat dealer ( NJ ) and a truck dealer,the boat dealer didn't find them using part #mer8306071630. The truck dealer would only sell them by the case,because they didn't carry them on a regular basis, their part #156071630A. Does anybody know where I can by these filters. Thanks in advance; Bill
need oil filter Hino wo4cti 210 hp 1990-gctid367666
If all else fails, you can try these guys. I'll be down on the boat tomorrow and can grab the filter # if you need it:
http://www.baldwinfiltersrus.com/
(no affiliation - just a quick Google search. But I do run Baldwin filters)
________________
1989 Bayliner 3270
Lots of places on the internet have them.
W06 Oil Filter Baldwin B7014
W06 Oil Filter Hino 15607-1630
W06 Oil Filter NAPA 7014
Thanks for all your help. The filter for a 150hp is probably the same as the one for the 210hp. Thanks again, Bill
Started boating 1965
cubair wrote:
Gordon, Thanks for the numbers. The picture of the Baldwin #B7014 looks like it about 2'' smaller than the Hino filters that I have been using ? Bill
As far as I know all the 4 cyl Hinos use the same filters. Older ones use an insert while the newer ones use spin on filters.
