I have a 3288 MY. I am going to install the pump down in the cave. I would like to use the thru hull line that feeds the head. I will place a tee in the line but need to know if I require some kind of valve (backwater valve ?) on the head side of the line ?????? Any kind of info would be appreciated.
Washdown pump instalation ?-gctid367407
Mine is located in the cave however I had to add a second through hull because it would suck air through the toilet.
The routing that I used was behind the trim above the medicine cabinet in the head. I used ridged plastic from the anchor locker to the helm bulkhead
I have my washdown pump tee'd off the head supply line. My wash-down hose connection has it's own check valve, and the electric pump for the toilet does also. If yours sucks air from either side, just install check valves. They're one-way valves that only allow water to go one direction. Standard hardware store item.
On my former 305, I had a hose outlet in the cockpit and one on the bow, difficult, but not impossible to route. On my current 2858, the outlet is in the cockpit, where I use a 10' hose and nozzle. I just add a hose for cleaning the bow. Maybe someday I'll run a line to an outlet forward...
Jeff & Tara (And Hobie too)Lake Havasu City, AZ
|Current: 2022 Sun Tracker Sport Fish 22 XP3 w/ Mercury 200
And 13 others...
I did not install any check valves and have had no issue. I have a Raritan Sea Era head with a seperate water pump.
Jeff it turns out there is a large open PVC conduit that runs front to back in the 305 under the galley. It runs from the mid cabin mechanical space to the forward berth. I used this to run my tubing forward.
Jim McNeely
Twin 5.7s with Bravo2 drives
Brighton, Michigan USA
MMSI # 367393410
That's exactly where I ran it Jim. I haven't poked around in the belly of the 2858 yet, so I'll just need that longer hose. Maybe next year...
And 13 others...
Good luck, it is a nice upgrade and having the hose neatly tucked into the large foredeck locker is great!
Trev
