Where can i find a diesel fule sending unit for my boat? Its a 1989 3288 powerd by twin Hino diesel's. Aluminum skyline fule tanks 120 gallons each "i think". mike
3288 Fule sending unit-gctid367331
The sending units are in the top of the tank. You can reach the port sie from the aft hanging locker. You have to take the bottom out at the step. I do not know if you can get the starboard one out without removing the tank. Your tanks are 100 gallon each
jmcannonball wrote:
I replaced m3888 guages with these:
http://www.wemausa.com/
Used my original Faria guages.
Starboard fule sending unit is the one giving me the problem. I switched the fule guages and got the same results. Port side half tank starboard side full tank. so the guages are good. They are Faria guages. I guess ill try to call faria to find the proper sending unit. Thanks mike
FishingFool wrote:
Those look nice.. I like the fact that they are vertical, stainless and no float arm.. This should make them last much longer.. Also, I see they have dual station which I"m sure you got. Do you remember which one you got? Or how much $ they cost?
MMSI: 338030604
