Hino EH700ti injection timer-gctid557561
    Hi Guys,
    I have a problem with an injector timer for a Hino EH 700ti engine that we cannot open for adjustment. Can anyone suggest where I can find a replacement.
    I have had smoke problems for some time with both engines blowing so we rebuilt, cleaned & adjusted to Hino specs the engines, turbos, injectors & everything else we could lay our hands on. The Starboard engine is fine now but the Port still has a smoke problem. We swapped the timers from one engine to the other & away went the smoke problem so we have narrowed it down to the timer needing adjustment. We have had it to an engineers shop but still cannot open so I need to replace. Can anyone help.
    Call North Harbor diesel in Anacortes, Wa.
    Started boating 1965
      Thank you. Looks like I have found a replacement in Cebu in the Philippines which is much closer as I am in Manila.
