1985 hino 110-gctid556151
    Looking at a 1985 3270 with hino 110 with 2042 hrs is this alot . Tried doing a search with no luck can someone help me out here.thank you
    2005 c-dory 22ft. Sold 5 2014
    1985 3270 110 hino
    cruising the CA. delta
    Assuming a reasonable level of attention to regular maintenance, 2,000 hours on a Hino is nothing.
    It's just getting broken in.
    You will love the 32xx. It's like mother nature designed the perfect boat.
    I may be a bit biased :P
    Midnight Star
    1996 3587
    Twin diesels, Hino 250's
    Ladysmith, BC
    History: 1996 - 2655, 2001 - 2855, 1984 - 3270
      + 1 on the maintenance. Have been out on the boat for a sea trial? Keep us posted and send some pictures.
      "Martini's Law"
      Nova Scotia, Canada
        Thanks for the quick replies. Put a deposit down and hopefully sea trial on Wednesday with inspection. If this goes through and think it will those of you who float around on the ca delta in the Isleton area might want to stay clear for awhile. If it doesn't go through I think I'm going to take a break from boat shopping as this will be the 2nd survey in 1 week the first one did not apprais high enough for the seller and he would not come off his asking price.
        1985 3270 110 hino
          Good luck with this one! Keep us posted.
          You've know doubt read boat the fuel tank issues on these models if you been searching on this site. Some other things to watch out is the condition of all the hoses and lines in general. I've had to replace quite bit of water/drain hose. Condition of all covers. Ask if the water tank has been replaced and make sure the surveyor checks this area (I just had to remove mine because of leak). Ask if the cutlas bearings have been replaced. Pay close attention to the stuffing box hoses as mine needed to be replaced. Inspect all covers and enclosures.
          These aren't big things but areas to be aware of that I'm discovering now. But, I enjoying doing these projects...any it's only $$$$.
          Hope that helps.
          "Martini's Law"
          Nova Scotia, Canada
            Completed survey today went well but did find that nether alternaters were puting out, stbd engine with more then normal vibration possibly motor mount. So does anyone know where I go for alternaters for a 1985 hino 4 cycl.
            thanks
            1985 3270 110 hino
              Any good alternator shop should be able to repair them.
              Started boating 1965
