We have a 1992 3688 and are thinking about replacing the original L shaped settee in the main cabin. Actually, the upholstry is still good but the foam holds up for about two minutes before you are sitting on a hard and uncomfortable surface. How is the settee attached? There are three sections and it seems to be cemented in and I don't want to destroy things in a stupid attempt at removing them?
Are they glued" Seems like their is a plywood backing.
Hopefully they aren't screwed in from the bottom.
Thanks,
Corky
Thanks,
Corky
