32xx plastic window filler replacement-gctid364225
  • IslandHop
    Photos please
    Photos are on the way! I only have them of the finished project but you will be able to get the idea.
  • Nikko
    remember - pictures or it didn't happen
    Guest started a topic 32xx plastic window filler replacement-gctid364225
    This winter on top of many other projects I replaced those horrible looking plastic filler pieces in the back of the window frames. I took the old pieces out and brought them to a glass company as a template and had them made out of gray tinted glass. I turned the L bracket around that held in the piece so the glass will now be about level with the frame. A little caulk behind and around the outside of the new glass and it looks better than I could have ever imagined. It matches the windows all the way around. Easy to clean and it shines like the rest of the glass. I haven't seen this project on this site yet so I just wanted to share it with my bayliner family and friends.
