I figured I would have to sand it and paint it. Never occured to me to try and re-gelcoat it. I have never used gel coat....
Rudder Packing and Boot Stripe Question (39)96 3988-gctid364099
pete oettinger wrote:
I ended up taking my Port side apart and measuring the packing- ws 3/8.
Yes Bootstripe is gelcoat which is now permanently scratched by crewman with scotchbrite. Could not even rub it out with rubbing compound. Bummer.
Worst case - you end up going through the factory dark stripe and get into the white. If you do then I would paint rather than gelcoat.
I use Interlux boot stripe paint, dark blue, it will last for years with 2 coats, use a fine brush, use very good quality masking and be sure to press the tape edges down hard.
Guest repliedI ended up taking my Port side apart and measuring the packing- ws 3/8.
I repacked my 2001 3988 with two wraps of 5/16 flax. Check with Don at marinehardware.com. They still have a lot of the bayliner specs for running gear.
Guest repliedThanks, I will look at that!
Guest repliedSomeone advised me that the bootstripe is gel coat. Before you try to paint, it may be worth hitting it with a good cutting wax, and then buff it out.
Does anyone know what size packing is used on the rudder posts on my '96 3988? I repacked the starboard side years ago and alertly did not write down the size. Pulled the generator the other day, port side has never been repacked- I don't think there is enough there to measure.
Also anyone know the make/color of the original bootstripe paint? One of my helpers was cleaning the water line with scotchbrite and did the boot stripe too.....
