We took the boat out today and were enjoying the sunshine. When we came back we plugged into the dock and the inverter faulted out. This happened once before when we lost power. Took all the power off the inverter, both AC input and DC input and after a period of time it reset itself and came back on.
Well this time it did not reset itself. I shut everything off to the boat, and to the inverter (AC and DC) let it set for at least 20 minutes and when I put the power back to the unit, the fault light went out, but could not restart the unit. Completely dead. No lights, nothing.
This is a TRACE 2512U with a remote panel. Anyone have any suggestions, on what to do, where and if I can get it serviced, or ?
I have disconnected all AC connections and wired the AC input to the AC output. That is getting us AC power for now. But that also means that the batteries are not being charged. I have shut off the power to everything except the heads, shower sump and the internet (which will be off when I am done). But the batteries won't last for every without a charge.
Anyone have any suggestions. Not looking forward to replacing this unit. That is an expense I had not planned on at this time. Does anyone know where to have them serviced?
Your help will be GREATLY APPRECIATED. Thank you.
