Just curious where in Vancouver (area) folks go for things like raw water pump impellers for Hinos?
Hino raw water pump impeller - where in Vanccouver?
You might try Marine Parts Supply of Canada; they advertise Hino parts in some of the trade journals:
1520 Stewart Ave.
Nanaimo, BC V9S 4E1
phone: (250) 754-5585
toll free: (866) 278-4466
fax: (250) 754-9471
email: [email protected]
Mon - Fri 8:30 - 5:00
Saturday 8:30 - 5:00
Sunday Closed
Note there are alternates to Hino factory impellers - just look-up at the many on-line parts websites. Good luck, Doug S.
If all else fails, contact the Hino distributor for all of Western Canada in Nanaimo, Anchor Marine, 1-866-278-4466 (HINO). They have the best supply of Hino marine parts of anyone I have seen except North Harbor Diesel in Anacortes, Wa.
Started boating 1965
On the cover of my pump it was stamped with
Johnson
F7B 902
10-24253-2
N-10
F7B 902 is the pump TYPE.
10-24253-2 Is the pump NUMBER.
Bayliner got the engine from US Marine, US Marine got the engine from HINO. Hino built the engine for US Marine. Most of the raw water pumps were OEMed from Johnson.
With the Manufactor, Type and Number you should be able go to any retailer (marine supplies usually charge more) who carries Johnson pumps and get an Impeller.
In the above case F7 is the key, Johnson makes two impellers.
Jabsco also makes replacement impellers for Johnson Pumps.
09-1028BT-1 Made of MC97 which is Neoprene. Replaces Jabsco 17937-0001
09-1028B-9 Made of Nitrile and is oil resistant. Replaces Jabsco 17937-00003
The only gotcha is you need to get the kit which has a paper gasket.
Hope this helps.
call 1.866.278.4466 i can not remember the correct name ancorage marine parts i think i have the number stored in my phone with out the name ..............but they are in bc and have eveything for hinos a hino truck dealer will not have what your looking for ........ they ship over night ...........i have used them many time in atlantic canada
NEIL S
thanks all - ordered from Marine Parts Supply (Nanaimo) - aka "1.866.278.4466".
Found their "at my door" prices (parts plus shipping) to be equivalent to what I'd pay locally , but without having to add the time or gas expense. Their correspondence was timely and professional, both on the phone and via email. Provided the rest of the experience is the same - they have a new customer.
Side note to "Merlin4087" - the phone number for BC Pumps is out of order - guessing they're not still around...
________________
1998 Bayliner 4788
1989 Bayliner 3270 - SOLD-
Shocking wrote:
This may be stupid but...
Could you call a Hino truck store? I know there's one in Langley anyway, so there must be more. I would think they'd at least have access to them.
Frank
"Safe Boating is No Accident"
Everett Sail and Power Squadron
Bc marine pump is no longer there. Think he moved to pender harbour, not sure that he is still in business at all.
Steve
http://threebranchsupply.com/ for the impeller and the sender1989 26' then 1994 32' now 2001 39'
